forum.datacad.com • View topic - File Sync
File Sync
PostPosted: Thu May 05, 2016 8:43 am
by Support@aci.bz
Hello,
I have two users who use datacad 18. They work from different locations and want to be able to sync their files so that they are using the same layers and templates. What sync client would you users recommend? I assumed someone on here has a similar setup and could provide advice. Thank you for your time.
Re: File Sync
PostPosted: Thu May 05, 2016 3:37 pm
Any sync client that can sync folders & files should work. Security restrictions at each location for your users might make one sync client work better than another. I prefer Goodsync, but I know others have had good success with Dropbox.
Re: File Sync
PostPosted: Fri May 06, 2016 8:15 am
by jimgoodman
We have been using Dropbox for Business for several years with great success, but like Josh says (and he is always right) there are many "Cloud" alternatives out there with a wide range of costs and features..
Re: File Sync
PostPosted: Fri May 06, 2016 12:05 pm
