#68985 by wvar
Tue May 24, 2016 1:37 am
Anyone else find that cleaning up smart walls using 1 Line or 2 Line Trim doesnt always work. I have found that to be especially the case when moving walls to another layer and then attempting a trim. Yes the walls are on the same layer. Layer Search on can help even if the walls to be trimmed are on the same layer.
#68986 by Roger D
Tue May 24, 2016 7:33 am
With 1 Line trim, sometime you need to make sure you are picking the control line of the smart wall.
If the z base/heights being different make it hard to clean.
Sometimes the wall may have an end with cap on, so when trimming the other end, it appears not to clean until you check that node and make sure cap is off.
