Text Search & Change Function
Mon Jul 18, 2016 10:00 pm
by LotharQ
Hello All,
I'm almost embarrassed to ask this but is there a specific text search & change function in Datacad? I have quite a few drawings that one of the builders that I deal with uses repeatedly and I get tired of having to scour the drawings for 2009 or 2006 to change to the current code cycle.
Thank you
Re: Text Search & Change Function
Tue Jul 19, 2016 7:25 am
There is a macro "Scrive" that has that function in it.
Also, you can do a Change/Text/Contents and Mask/Text/Text Mask for say 2006, I think you would have to type 2009 each time it finds 2006.
Tue Jul 19, 2016 7:53 am
This would certainly be a great tool!
Does Scrive work with ParaText and MText?
Tue Jul 19, 2016 8:20 am
I don't think Scrive will pick it up, but the text mask will work if you select PText at the 3rd page of items.
Tue Jul 19, 2016 8:52 am
by Mark F. Madura
From the 'left-hand' Edit menu:
Change --> Text --> Contents --> Mask --> Entity --> Text --> Text Mask
or
Change --> Text --> Contents --> Mask --> Entity --> PText --> Text Mask
or
Change --> Text --> Contents --> Mask --> Entity --> MText --> Text Mask
Tue Jul 19, 2016 11:46 am
The Subtext macro works well also for substitution of plain text, and converting to all caps. Doesn't work on MText/PText.
Tue Jul 19, 2016 1:16 pm
by LotharQ
Thank you Mark,
I have never actual used mask before in all of the time that I have used Datacad, mainly because I understand it. For those of you who use the mask command quite often in what ways do you use it?
Thu Jul 21, 2016 10:33 am
by dmartens
Does this not work in DC15? I have all the steps but when I try to select the text it can't find it. This would be a big help if it works in DC15. Thank again for the help.
Dan
Thu Jul 21, 2016 10:57 am
Thu Jul 21, 2016 1:12 pm
It should work in v15, I can check later when at another CPU. Is layer search on?
Uses: Esp when getting files from other sources, to quickly mask by color to change to my office standard colors, and select only polylines to change the fill color.
Fri Jul 22, 2016 12:09 pm
by dmartens
Layer search is on. was able to Ctrl-r and select text for editing but when I go thru the mask options and enter the text I am looking for then try to select the text it says no object found. this would have been a nice one. maybe I'm just doing something wrong. Thanks again.
Dan
Tue Aug 02, 2016 10:11 am
by melina
My response may be late, but if you have the dhText macro, the search & replace function still works. Of course, not for Ptext or Mtext though.
