#69692 by Neil Blanchard
Mon Aug 29, 2016 9:50 am
Hi,
I usually use Steel Pro for W section, and other rolled sections. I just tried it for a bar joist - I set the depth to 10" and the bearing to 2 1/2". The resulting output has the bearing at 2 17/32" and the total depth at 11 1/4" - which is very confusing.
#69697 by joshhuggins
Mon Aug 29, 2016 11:32 am
Hi Neil, I input the same values and my overall height was 11-1/4" also, but my bearing was correct at 2-1/2". I tried Rel. Cart. and Dir. Dist. with the same results. I found that 10" shows up as the distance between the one edge of the angle to the the start of the opposite. I don't work that type of joist system much so I couldn't tell you if it actually worked correctly in the past or not. Maybe something in the macro used to reference something like mirroring the profile of the angle for the top and bottom chords and something in Datacad has changed causing the draw point to be at the wrong side of the profile or something? Who knows. I think Datacad has the rights to the macro now so maybe Dave can peek at it? I tested a 12" joist with the same result. Would be nice if we could pick the section to be used for the top and bottom chords.
#69698 by Neil Blanchard
Mon Aug 29, 2016 1:35 pm
Thanks Josh, for checking.
I compared this to the bar joist symbols we have available, and those have the total depth of the joist correct. As I understand bar joists, they have standard depths and weights, so the macro could be set up just like it is for all the other steel items it draws. I needed to draw the 10K1 joist, which is the smallest standard size, apparently.
Here's all the standard sizes:
SJI K-SERIES JOISTS:
10″ Deep Steel Joist: 10K1 (NOTE: 8K1 joists no longer listed by SJI)
12″ Deep Steel Joist: 12K1, 12K3, 12K5
14″ Deep Steel Joist: 14K1, 14K3, 14K4, 14K6
16″ Deep Steel Joist: 16K2, 16K3, 16K4, 16K5, 16K6, 16K7, 16K9
18″ Deep Steel Joist: 18K3, 18K4, 18K5, 18K6, 18K7, 18K9, 18K10
20″ Deep Steel Joist: 20K3, 20K4, 20K5, 20K6, 20K7, 20K9, 20K10
22″ Deep Steel Joist: 22K4, 22K5, 22K6, 22K7, 22K9, 22K10, 22K11
24″ Deep Steel Joist: 24K4, 24K5, 24K6, 24K7, 24K8, 24K9, 24K10, 24K12
26″ Deep Steel Joist: 26K5, 26K6, 26K7, 26K8, 26K9, 26K10, 26K12
28″ Deep Steel Joist: 28K6, 28K7, 28K8, 28K9, 28K10, 28K12
30″ Deep Steel Joist: 30K7, 30K8, 30K9, 30K10, 30K11, 30K12
SJI KCS-SERIES JOISTS:
10″ Deep Steel Joist: 10KCS1, 10KCS2, 10KCS3
12″ Deep Steel Joist: 12KCS1, 12KCS2, 12KCS3
14″ Deep Steel Joist: 14KCS1, 14KCS2, 14KCS3
16″ Deep Steel Joist: 16KCS2, 16KCS3, 16KCS4, 16KCS5
18″ Deep Steel Joist: 18KCS2, 18KCS3, 18KCS4, 18KCS5
20″ Deep Steel Joist: 20KCS2, 20KCS3, 20KCS4, 20KCS5
22″ Deep Steel Joist: 22KCS2, 22KCS3, 22KCS4, 22KCS5
24″ Deep Steel Joist: 24KCS2, 24KCS3, 24KCS4, 24KCS5
26″ Deep Steel Joist: 26KCS2, 26KCS3, 26KCS4, 26KCS5
28″ Deep Steel Joist: 28KCS2, 28KCS3, 28KCS4, 28KCS5
30″ Deep Steel Joist: 30KCS3, 30KCS4, 30KCS5
SJI LH-SERIES JOISTS:
18″ Deep Steel Joist: 18LH02, 18LH03, 18LH04, 18LH05, 18LH06, 18LH07, 18LH08, 18LH09
20″ Deep Steel Joist: 20LH02, 20LH03, 20LH04, 20LH05, 20LH06, 20LH07, 20LH08, 20LH09, 20LH10
24″ Deep Steel Joist: 24LH03, 24LH04, 24LH05, 24LH06, 24LH07, 24LH08, 24LH09, 24LH10, 24LH11
28″ Deep Steel Joist: 28LH05, 28LH06, 28LH07, 28LH08, 28LH09, 28LH10, 28LH11, 28LH12, 28LH13
32″ Deep Steel Joist: 32LH06, 32LH07, 32LH08, 32LH09, 32LH10, 32LH11, 32LH12, 32LH13, 32LH14, 32LH15
36″ Deep Steel Joist: 36LH07, 36LH08, 36LH09, 36LH10, 36LH11, 36LH12, 36LH13, 36LH14, 36LH15
40″ Deep Steel Joist: 40LH08, 40LH09, 40LH10, 40LH11, 40LH12, 40LH13, 40LH14, 40LH15, 40LH16
44″ Deep Steel Joist: 44LH09, 44LH10, 44LH11, 44LH12, 44LH13, 44LH14, 44LH15, 44LH16, 44LH17
48″ Deep Steel Joist: 48LH10, 48LH11, 48LH12, 48LH13, 48LH14, 48LH15, 48LH16, 48LH17
SJI DLH-SERIES JOISTS:
52″ Deep Steel Joist: 52DLH10, 52DLH11, 52DLH12, 52DLH13, 52DLH14, 52DLH15, 52DLH16, 52DLH17
56″ Deep Steel Joist: 56DLH11, 56DLH12, 56DLH13, 56DLH14, 56DLH15, 56DLH16, 56DLH17
60″ Deep Steel Joist: 60DLH12, 60DLH13, 60DLH14, 60DLH15, 60DLH16, 60DLH17, 60DLH18
64″ Deep Steel Joist: 64DLH12, 64DLH13, 64DLH14, 64DLH15, 64DLH16, 64DLH17, 64DLH18
68″ Deep Steel Joist: 68DLH13, 68DLH14, 68DLH15, 68DLH16, 68DLH17, 68DLH18, 68DLH19
72″ Deep Steel Joist: 72DLH14, 72DLH15, 72DLH16, 72DLH17, 72DLH18, 72DLH19
