XREF CLIP CUBE INFO BOX
PostPosted: Fri Oct 14, 2016 3:52 pm
by GARY247
Is there any way to turn off info on xref clip cubes so that it stays off? I cannot seem to find anything to turn it off and keep it that way.
Re: XREF CLIP CUBE INFO BOX
PostPosted: Fri Oct 14, 2016 4:04 pm
by David A. Giesselman
Info? What info?
PostPosted: Fri Oct 14, 2016 5:20 pm
??CLIPCUBE_DISPLAY=TRUE in .ini file? this turns on/offf the dashed line that indicates the clip cube??
PostPosted: Fri Oct 14, 2016 5:35 pm
Roger D wrote:??CLIPCUBE_DISPLAY=TRUE in .ini file? this turns on/offf the dashed line that indicates the clip cube??
Or from within the Preferences dialog.
PostPosted: Sat Oct 15, 2016 7:37 am
by GARY247
Sorry I did not make myself clear. It is when you go to edit a clip cube there is an info box at the bottom which causes everything to show up when you go to make an edit. It seems to appear every time I go to edit a clip cube and I was wondering if there was a way to keep it turned off as it just turns the clip cube in to a cluster mess.
PostPosted: Sun Oct 16, 2016 12:14 pm
can you post a screen shot, I don't see anything showing up.
PostPosted: Fri Nov 18, 2016 10:59 am
by GARY247
The base drawings have other clip cubes within the drawing. When I go to edit in another drawing every clip cup in the base drawing then appears blocking out the one I am trying to edit.[attachment=0]clip cube after going to edit.
PostPosted: Fri Nov 18, 2016 2:18 pm
An X-Clip stays off when you turn it off. A 3D ClipCube toggles on with a GTV.
Is the layer it is on locked?
PostPosted: Fri Nov 18, 2016 2:30 pm
by GARY247
The xref are not on a locked layer and it is done in 2d. I used clip cubes of exterior walls on 4 different building cross sections. This does not happen when I bring in the xref and clip it initially, only when I go to create a new clip cube or edit the existing one.
PostPosted: Fri Nov 18, 2016 3:15 pm
Right, we use 3D Clip Cubes for 2D work. 3D Clip Cubes are different things than X-Clip Cubes.
If you Control-Right Click on the XRef, is XRef Tools / Enable X-Clips toggled on? Is the ClipCube icon toggled on?
PostPosted: Thu Dec 01, 2016 9:15 am
by GARY247
Enable x-clip, x-slip, nesting and dynamic snapping are turned on. When I go to edit the clip cube every xref that it is associated with shows the base drawing shows up(two different drawings). The base drawing has multiple cross sections on it some with x-clips. The only way I seem to get to edit it is to make a new clip cube.
PostPosted: Tue Jan 03, 2017 5:18 pm
by GARY247
I solved the problem of editing a clip cube and having multiple clip cubes from the base drawing showing up once you click on edit. Right click and go to xref and click off nesting.
