#70651 by GARY247
Thu Jan 19, 2017 5:13 pm
I created a pak file in version 18 with the latest update and when I opened in with version 16 at home the drawing was all different. How do I correct this problem? Logging out of 18 every time I want to draw on a different computer is really not an option as it is too time consuming. I did not have this issue prior to doing the update.
#70697 by GARY247
Wed Jan 25, 2017 11:15 pm
I tried coping the drawing directly instead of using the pak process. I opened the same way. Xreferences were all different so I am assuming that the problem was created after I did the latest update to version 18.
#70699 by MtnArch
Thu Jan 26, 2017 7:19 am
This sounds like a pathing issue, or that the files that are being xref'd are not the same versions at home as you have at work.
#70702 by GARY247
Thu Jan 26, 2017 10:10 am
I didn't have the issue until after I did the update. I am going to try to open the drawing in 17 at work and save it to my thumb drive to see if that might shed some light on the issue.
#70705 by MtnArch
Thu Jan 26, 2017 11:22 am
Look at your paths in Preferences - these do NOT get updated when you upgrade (they never have, so it's not something new). I'm guessing that you changed it at work but not at home.
