i AM HAVING TROUBLE WITH A FILE THAT i IMPORTED A DWG FILE. i THINK IT IS A PROBLEM WITH 3D LINES. IS THERE A WAY TO CHANGE 3E LINES TO 2D LINES.
You can get the 3D Line Convert Macro from the Datacad Website.
Thanks! - Josh
The step you may need to do before using the 3D Line Convert, is to change the Z Base and Z Height to 0 for everything. Then when you use the 3D Line Convert, all the 3D line will be converted to 2D lines. The reason is the macro won't convert 3D line that have different Z heights at each end; only 3D lines that are all level at one Z height.
