I have changed the drawing area font in the Program Preferences. After working on some drawings, closing Datacad and then opening it the drawing are font has changed back to the default font. I am running version 18.04.01.02.
Any suggestions would be greatly appreciated.
Arthur Wood
CADD Manager
EH Danson Associates
St. Johnbury, Vermont
Hi Art, if you are talking about the Misc Tab's Drawing Area Font, I never remember where the actual Font name is used. I have to manually change the dcadwin.ini file in order to get the font name to stick but I don't see it applied anywhere. I know if you change the Size of the font there it changes the size of the font used in the PText dialog box. What onscreen text are you trying to change?
Thanks! - Josh Do. Or do not. There is no try. Josh's Digital Downloads is come back online soon. Stay tuned.
Josh, yes it is in the dcadwin.ini file. The default file did not have the line item for the font. I had to get the wordage from the Datacad website to add the font name. After adding the font name, everything works as it should. Here is what I added to the dcadwin.ini file:
