#2719 by Tony Blasio
Thu May 19, 2005 7:30 am
OK what I mentioned previously was easier in the old format. Let me mess with this idea. I will post my results.
#2722 by Neil Blanchard
Thu May 19, 2005 8:35 am
Hello:
Here's what some the hatch patterns that I purchased from Cheap Tricks look like:
(click on thumbnail for larger image)
There may be others, but these are the ones I found in a short search...these are 10 foot square areas and the scale is set to 32.
#2724 by Tony Blasio
Thu May 19, 2005 9:53 am
Here is the code for a combined CMU - Split face to match the previously posted image. The only draw back to this way of doing it is you can't have different colors.
[Header]
Scale=1
Angle=0
Display Scale=8
Segments=36
[Segments]
001=0,0,0,0,0,0,256
002=0,0,90,0,0,256,256,256,-256
003=0,0,0,184.320007324219,122.879997253418,112.639999389648,194.559997558594,10.2399997711182,-171.520004272461,7.67999982833862,-74.2399978637695,15.3599996566772,-181.759994506836
004=0,0,5,69.120002746582,215.039993286133,117.76000213623,189.440002441406,20.4799995422363,-171.520004272461,15.3599996566772,-74.2399978637695,30.7199993133545,-181.759994506836
005=0,0,10,135.679992675781,227.839996337891,110.080001831055,227.839996337891,17.9200000762939,-43.5200004577637,23.0400009155273,-135.679992675781,12.8000001907349,-168.960006713867
006=0,0,15,89.5999984741211,250.880004882813,115.199996948242,207.360000610352,35.8400001525879,-43.5200004577637,38.4000015258789,-135.679992675781,28.1599998474121,-168.960006713867
007=0,0,20,110.080001831055,145.919998168945,171.520004272461,138.240005493164,20.4799995422363,-140.800003051758,17.9200000762939,-104.959999084473,12.8000001907349,-81.9199981689453
008=0,0,25,145.919998168945,110.080001831055,194.559997558594,115.199996948242,28.1599998474121,-140.800003051758,35.8400001525879,-104.959999084473,30.7199993133545,-81.9199981689453
009=0,0,30,184.320007324219,130.559997558594,92.1600036621094,197.119995117188,12.8000001907349,-84.4800033569336,10.2399997711182,-125.440002441406,7.67999982833862,-166.399993896484
010=0,0,35,69.120002746582,38.4000015258789,161.279998779297,197.119995117188,28.1599998474121,-84.4800033569336,20.4799995422363,-125.440002441406,15.3599996566772,-166.399993896484
011=0,0,40,112.639999389648,186.880004882813,140.800003051758,122.879997253418,10.2399997711182,-112.639999389648,7.67999982833862,-71.6800003051758,20.4799995422363,-130.559997558594
012=0,0,45,112.639999389648,94.7200012207031,140.800003051758,215.039993286133,20.4799995422363,-112.639999389648,15.3599996566772,-71.6800003051758,38.4000015258789,-130.559997558594
013=0,0,50,151.039993286133,94.7200012207031,110.080001831055,181.759994506836,5.11999988555908,-94.7200012207031,12.8000001907349,-156.160003662109,15.3599996566772,-79.3600006103516
014=0,0,60,158.720001220703,112.639999389648,122.879997253418,168.960006713867,12.8000001907349,-104.959999084473,5.11999988555908,-122.879997253418,10.2399997711182,-94.7200012207031
015=0,0,65,66.5599975585938,112.639999389648,215.039993286133,168.960006713867,28.1599998474121,-104.959999084473,10.2399997711182,-122.879997253418,20.4799995422363,-94.7200012207031
016=0,0,70,130.559997558594,81.9199981689453,140.800003051758,151.039993286133,7.67999982833862,-48.6399993896484,15.3599996566772,-81.9199981689453,10.2399997711182,-112.639999389648
017=0,0,75,38.4000015258789,58.8800010681152,140.800003051758,243.199996948242,15.3599996566772,-48.6399993896484,30.7199993133545,-81.9199981689453,20.4799995422363,-112.639999389648
018=0,0,80,143.360000610352,232.960006713867,107.519996643066,199.679992675781,17.9200000762939,-112.639999389648,7.67999982833862,-133.119995117188,15.3599996566772,-125.440002441406
019=0,0,85,166.399993896484,48.6399993896484,107.519996643066,222.720001220703,35.8400001525879,-112.639999389648,15.3599996566772,-133.119995117188,30.7199993133545,-125.440002441406
020=0,0,90,158.720001220703,122.879997253418,94.7200012207031,225.279998779297,15.3599996566772,-79.3600006103516,10.2399997711182,-156.160003662109,5.11999988555908,-158.720001220703
021=0,0,95,66.5599975585938,215.039993286133,186.880004882813,225.279998779297,30.7199993133545,-79.3600006103516,10.2399997711182,-156.160003662109,10.2399997711182,-158.720001220703
022=0,0,100,117.76000213623,202.240005493164,158.720001220703,186.880004882813,17.9200000762939,-99.8399963378906,15.3599996566772,-81.9199981689453,17.9200000762939,-186.880004882813
023=0,0,105,163.839996337891,248.320007324219,158.720001220703,186.880004882813,35.8400001525879,-99.8399963378906,30.7199993133545,-81.9199981689453,35.8400001525879,-186.880004882813
024=0,0,110,99.8399963378906,56.3199996948242,135.679992675781,168.960006713867,20.4799995422363,-66.5599975585938,10.2399997711182,-135.679992675781,15.3599996566772,-148.479995727539
025=0,0,115,238.080001831055,56.3199996948242,135.679992675781,168.960006713867,38.4000015258789,-66.5599975585938,20.4799995422363,-135.679992675781,30.7199993133545,-148.479995727539
026=0,0,120,30.7199993133545,87.0400009155273,143.360000610352,199.679992675781,12.8000001907349,-171.520004272461,15.3599996566772,-79.3600006103516,17.9200000762939,-104.959999084473
027=0,0,125,53.7599983215332,110.080001831055,166.399993896484,222.720001220703,28.1599998474121,-171.520004272461,30.7199993133545,-79.3600006103516,35.8400001525879,-104.959999084473
028=0,0,130,87.0400009155273,30.7199993133545,199.679992675781,143.360000610352,7.67999982833862,-56.3199996948242,10.2399997711182,-110.080001831055,20.4799995422363,-143.360000610352
029=0,0,135,110.080001831055,53.7599983215332,222.720001220703,166.399993896484,15.3599996566772,-56.3199996948242,20.4799995422363,-110.080001831055,38.4000015258789,-143.360000610352
030=0,0,140,10.2399997711182,235.520004272461,125.440002441406,143.360000610352,15.3599996566772,-92.1600036621094,17.9200000762939,-79.3600006103516,10.2399997711182,-107.519996643066
031=0,0,145,112.639999389648,74.2399978637695,125.440002441406,166.399993896484,30.7199993133545,-92.1600036621094,35.8400001525879,-79.3600006103516,20.4799995422363,-107.519996643066
032=0,0,150,222.720001220703,15.3599996566772,99.8399963378906,176.639999389648,10.2399997711182,-71.6800003051758,20.4799995422363,-158.720001220703,17.9200000762939,-145.919998168945
033=0,0,155,199.679992675781,156.160003662109,168.960006713867,176.639999389648,20.4799995422363,-71.6800003051758,38.4000015258789,-158.720001220703,35.8400001525879,-145.919998168945
034=0,0,160,53.7599983215332,158.720001220703,143.360000610352,199.679992675781,15.3599996566772,-107.519996643066,12.8000001907349,-97.2799987792969,10.2399997711182,-156.160003662109
035=0,0,165,30.7199993133545,66.5599975585938,166.399993896484,222.720001220703,30.7199993133545,-107.519996643066,28.1599998474121,-97.2799987792969,20.4799995422363,-156.160003662109
036=0,0,170,69.120002746582,97.2799987792969,156.160003662109,174.080001831055,23.0400009155273,-84.4800033569336,15.3599996566772,-115.199996948242,20.4799995422363,-112.639999389648
Now if you want them seperate but with the same scale here isa CMU witch a scale of 1 and the Fill-11 with a scale of 1.
CMU
[Header]
Scale=1
Angle=0
Display Scale=9
Segments=2
[Segments]
001=0,0,0,0,0,0,256
Fill-11-1
[Header]
Scale=1
Angle=0
Display Scale=10
Segments=34
[Segments]
001=0,0,0,184.32,122.88,112.64,194.56,10.24,-171.52,7.68,-74.24,15.36,-181.76
002=0,0,5,69.12,215.04,117.76,189.44,20.48,-171.52,15.36,-74.24,30.72,-181.76
003=0,0,10,135.68,227.84,110.08,227.84,17.92,-43.52,23.04,-135.68,12.8,-168.96
004=0,0,15,89.6,250.88,115.2,207.36,35.84,-43.52,38.4,-135.68,28.16,-168.96
005=0,0,20,110.08,145.92,171.52,138.24,20.48,-140.8,17.92,-104.96,12.8,-81.92
006=0,0,25,145.92,110.08,194.56,115.2,28.16,-140.8,35.84,-104.96,30.72,-81.92
007=0,0,30,184.32,130.56,92.16,197.12,12.8,-84.48,10.24,-125.44,7.68,-166.4
008=0,0,35,69.12,38.4,161.28,197.12,28.16,-84.48,20.48,-125.44,15.36,-166.4
009=0,0,40,112.64,186.88,140.8,122.88,10.24,-112.64,7.68,-71.68,20.48,-130.56
010=0,0,45,112.64,94.72,140.8,215.04,20.48,-112.64,15.36,-71.68,38.4,-130.56
011=0,0,50,151.04,94.72,110.08,181.76,5.12,-94.72,12.8,-156.16,15.36,-79.36
012=0,0,60,158.72,112.64,122.88,168.96,12.8,-104.96,5.12,-122.88,10.24,-94.72
013=0,0,65,66.56,112.64,215.04,168.96,28.16,-104.96,10.24,-122.88,20.48,-94.72
014=0,0,70,130.56,81.92,140.8,151.04,7.68,-48.64,15.36,-81.92,10.24,-112.64
015=0,0,75,38.4,58.88,140.8,243.2,15.36,-48.64,30.72,-81.92,20.48,-112.64
016=0,0,80,143.36,232.96,107.52,199.68,17.92,-112.64,7.68,-133.12,15.36,-125.44
017=0,0,85,166.4,48.64,107.52,222.72,35.84,-112.64,15.36,-133.12,30.72,-125.44
018=0,0,90,158.72,122.88,94.72,225.28,15.36,-79.36,10.24,-156.16,5.12,-158.72
019=0,0,95,66.56,215.04,186.88,225.28,30.72,-79.36,10.24,-156.16,10.24,-158.72
020=0,0,100,117.76,202.24,158.72,186.88,17.92,-99.84,15.36,-81.92,17.92,-186.88
021=0,0,105,163.84,248.32,158.72,186.88,35.84,-99.84,30.72,-81.92,35.84,-186.88
022=0,0,110,99.84,56.32,135.68,168.96,20.48,-66.56,10.24,-135.68,15.36,-148.48
023=0,0,115,238.08,56.32,135.68,168.96,38.4,-66.56,20.48,-135.68,30.72,-148.48
024=0,0,120,30.72,87.04,143.36,199.68,12.8,-171.52,15.36,-79.36,17.92,-104.96
025=0,0,125,53.76,110.08,166.4,222.72,28.16,-171.52,30.72,-79.36,35.84,-104.96
026=0,0,130,87.04,30.72,199.68,143.36,7.68,-56.32,10.24,-110.08,20.48,-143.36
027=0,0,135,110.08,53.76,222.72,166.4,15.36,-56.32,20.48,-110.08,38.4,-143.36
028=0,0,140,10.24,235.52,125.44,143.36,15.36,-92.16,17.92,-79.36,10.24,-107.52
029=0,0,145,112.64,74.24,125.44,166.4,30.72,-92.16,35.84,-79.36,20.48,-107.52
030=0,0,150,222.72,15.36,99.84,176.64,10.24,-71.68,20.48,-158.72,17.92,-145.92
031=0,0,155,199.68,156.16,168.96,176.64,20.48,-71.68,38.4,-158.72,35.84,-145.92
032=0,0,160,53.76,158.72,143.36,199.68,15.36,-107.52,12.8,-97.28,10.24,-156.16
033=0,0,165,30.72,66.56,166.4,222.72,30.72,-107.52,28.16,-97.28,20.48,-156.16
034=0,0,170,69.12,97.28,156.16,174.08,23.04,-84.48,15.36,-115.2,20.48,-112.64
#2732 by WizArtist
Thu May 19, 2005 3:03 pm
That worked like a charm. I input the hatches separated as I prefer the grout lines to be more pronounced. That was a lot of work and I appreciate the time you took to make that work.
Thank you.
#9218 by steve nollet
Wed Jan 18, 2006 10:15 am
I'm totally new to all of this. I bought Cheap tricks mostly for the shake and board & batten hatchs but I can't use them. The only file with the circle-in-a-square icon is dacadwin.pat. It's 87Kb compared to 1Kb for most the datacad supplied hatches and it doesn't have the DHP extension. I tried copying it to the support files folder with windows browser and renaming the extension but it doesn't show up under available hatches. What should I be doing?
#9223 by Neil Blanchard
Wed Jan 18, 2006 10:44 am
Greetings Steve,
In the Hatch/Manage dialog, you can use the Convert button: browse to where this new PAT file is, and then it will create a DHP file for each of the hatch patterns contained in the PAT file. :)
#9227 by steve nollet
Wed Jan 18, 2006 11:17 am
Thank you Thankyou. :!: It didn't seem to work at first, but then suddenly there they all were! Odd scales, but use-able. Thanks for the quick reply
