Edit Attributes Quick key
PostPosted: Tue Jun 07, 2011 9:04 am
by GARY247
Not sure what the advantage is of using an attribute but required to use it because of cad standards. Is there a way to create a quick key for editing attributes rather than the multiple mouse clicks required by the software?
Re: Edit Attributes Quick key
PostPosted: Tue Jun 07, 2011 9:14 am
A couple ways.
Some, based on I think Josh Huggins thinking have modified our alt-key to edit text to first attempt a edit attribute.
H^170#^$^8#^S8^S2^F1^$^
\\ H- Change Text
this works good for 1 at a time.
Or you can use a Command Alias (or make it a Alt-Key also)
[sa]
comment=Change Symbol Attribute
alias=^170#^$^
This one, you can keep picking symbols without having to do the alt-key again.
PostPosted: Tue Jun 07, 2011 10:13 am
Right, this keyboard shortcut edits symbol attributes *and* text contents; depending on which one you are hovering the cursor over.
PostPosted: Wed Jun 08, 2011 3:10 pm
by GARY247
Not sure on the method here. I am assuming you are using notepad to change the MCR file. Is H^170#^$^8#^S8^S2^F1^$^
\\ H- Change Text
all one line to cut an paste in the the "H" line to create the key stroke (alt +H) or is this two different methods of creating a quick key.
Is alias=^170#^$^
another method to the create another quick key? With either of these methods to create the quick keys I understand what they should read as but not sure how to incorporate them into the MCR file. Can I create it with the "C" key instead of the "H" key?
PostPosted: Wed Jun 08, 2011 3:55 pm
any line that starts with \\ is ignored as comments, so the \\ H- Change Text is an extra line that is not required.
The Alias goes in the DcadWin.dca file, and is invoked by hitting the Ctrl-spacebar and the letter(s) codes assigned to the alias, I had used [sa].
PostPosted: Thu Jun 09, 2011 8:59 am
Is alias=^170#^$^ another method to the create another quick key? With either of these methods to create the quick keys I understand what they should read as but not sure how to incorporate them into the MCR file. Can I create it with the "C" key instead of the "H" key?
You can use any key, you will just be replacing the new command and losing the existing one.
You use a simple text editor like notepad to edit the file dcadwin.mcr, and should be able to copy & paste the line directly into the file.
All three lines need to be added into the DcadWin.dca file to make it an alias.
Code: Select all[sa]
alias=^170#^$^
If you want to use it as a keyboard macro, you would just use that portion
Code: Select allH^170#^$^
The $^ at the end, makes the macro select whatever the mouse is close to, it acts as hitting the enter key, or mouse pick.
PostPosted: Thu Jun 09, 2011 1:19 pm
by GARY247
Thanks for your help on this one. Most appreciated. I used alt "C" as it was a key seldom if ever used and the keys are closer together.
