#62205 by wwwylie
Sun Nov 03, 2013 10:51 pm
Although there is not "make unique" command for symbols like Sketchup has for its components, I have found a short work-around to creating a symbol in the current drawing only, which is essentially a "make unique" type of command. It all comes from using the "Paste as Symbol" command (Shift+Ctrl+V). If you are trying to make a unique symbols of one that is in the drawing and currently unexploded, you can use either of the following 2 methods:
    1. Go to Edit > Clipboard Select (Ctrl + E)
    2. Choosing entity (F1), select the symbol you want to "make unique" and then hit copy (S5 or Ctrl+C)
    3. Select an insertion point (if you had that option set).
    4. Go to Edit > Paste as Symbol (Shift+Ctrl+V) and insert the symbol where you want it. You will be prompted to give the symbol a name (the default is a long number string which seems to be unique, probably related to the time that you inserted the new symbol).
    5. Double-Click on the new symbol (or use the cool new Shift+Right Click if you have Inferencing turned on and have installed the new Beta) to open up the symbol editor.
    6. Ctrl+Right click on the original symbol and select Symbol Tools > Explode > to Original Layers.
    7. Use the layer manager to delete the current layer (provided it has nothing on it).
    8. Edit the symbol to your liking.
    9. Close the symbol (File > Close or Ctrl+F4) and select YES to save changes.
    10. You now have a unique symbol based in the drawing only.
Alternatively you could...
    1. Double-Click on the symbol you want to "make unique"(or use the cool new Shift+Right Click if you have Inferencing turned on and have installed the new Beta) to open up the symbol editor.
    2. Go to Edit > Clipboard Select (Ctrl + E)
    3. Either choose area (F3) and select everything (with Layer Search on), or hit Ctrl+A (with Layer Search on) to select everything, then hit copy (S5 or Ctrl+C)
    4. Select an insertion point (if you had that option set).
    5. Close the symbol (File > Close or Ctrl+F4) and select NO to save changes.
    6. Go to Edit > Paste as Symbol (Shift+Ctrl+V) and insert the symbol where you want it. You will be prompted to give the symbol a name (the default is a long number string which seems to be unique, probably related to the time that you inserted the new symbol).
    7. Double-Click on the new symbol (or use the cool new Shift+Right Click if you have Inferencing turned on and have installed the new Beta) to open up the symbol editor.
If you wish, you can Save-As the symbol and keep it on the hard drive as a DSF file for use in other drawings. You could also just use Clipboard Select to copy and paste it to another drawing, where it will be a unique symbol within that drawing alone.
#62207 by Neil Blanchard
Mon Nov 04, 2013 9:12 am
Wade, if I understand you correctly, this would be like exploding a symbol, but not having to exploded it. Changes to the one symbol would *not* affect the other instances of that symbol.
This could be useful. Maybe a way yo do it would be to have a Save As/Replace function all in one step?
#62210 by wwwylie
Mon Nov 04, 2013 11:35 am
This allows me to create a symbol that is unique to the drawing only without having to save it out to the hard drive. For example, I use bring in my standard details as unexploded symbols so I make changes to them on the hard drive I have to option to reload them in each drawing without having to duplicate the changes. If I have a drawing that needs a standard detail (say a footing for example) and then needs a second copy of it with a slight modification that I do not want to save out to a DSF file (soils engineer recommendations?), I can use this to create a "unique" copy of it and change that copy without affecting the original instance of the symbol within the drawing.
I find this to be similar to the way components work in Sketchup. I can now create symbols easily within the drawing for repeated information that I don't have to save out to my symbol library. I have also found this useful for posts that are of an odd dimension (that occur multiple times in one job), but that I don't foresee using all that often.
#62214 by joshhuggins
Mon Nov 04, 2013 4:19 pm
I use the Alt method you posted above which takes about 7 secs to Dbl Click, Ctrl+A, Pick insert point if turned on, close symbol, Ctrl+Shift+V. I try to copy the contents to my clipboard ahead of time before I leave the first symbol to save a step or two if I have enough forethought, but if there was a 'Save As New Symbol' option via the Ctrl+Right click 'Symbol Tools' context menu below the Save As, that would be pretty handy. Gets my vote. We use the heck out of the Ctrl+Shift+V. Would also love it if we could create multiple new symbols via Ctrl+Shift+V without it loosing the clipboard contents each time and having to go back to the source and re-copy and then Ctrl+Shift+V again to create the next unique symbol.
#62225 by wwwylie
Tue Nov 05, 2013 11:27 am
joshhuggins wrote:Would also love it if we could create multiple new symbols via Ctrl+Shift+V without it loosing the clipboard contents each time and having to go back to the source and re-copy and then Ctrl+Shift+V again to create the next unique symbol.
I had no idea this was the case, but if so then I second this idea.
