Symbol "Make Unique"
Posted: Sun Nov 03, 2013 10:51 pm
Although there is not "make unique" command for symbols like Sketchup has for its components, I have found a short work-around to creating a symbol in the current drawing only, which is essentially a "make unique" type of command. It all comes from using the "Paste as Symbol" command (Shift+Ctrl+V). If you are trying to make a unique symbols of one that is in the drawing and currently unexploded, you can use either of the following 2 methods:
Alternatively you could...
If you wish, you can Save-As the symbol and keep it on the hard drive as a DSF file for use in other drawings. You could also just use Clipboard Select to copy and paste it to another drawing, where it will be a unique symbol within that drawing alone.
- 1. Go to Edit > Clipboard Select (Ctrl + E)
2. Choosing entity (F1), select the symbol you want to "make unique" and then hit copy (S5 or Ctrl+C)
3. Select an insertion point (if you had that option set).
4. Go to Edit > Paste as Symbol (Shift+Ctrl+V) and insert the symbol where you want it. You will be prompted to give the symbol a name (the default is a long number string which seems to be unique, probably related to the time that you inserted the new symbol).
5. Double-Click on the new symbol (or use the cool new Shift+Right Click if you have Inferencing turned on and have installed the new Beta) to open up the symbol editor.
6. Ctrl+Right click on the original symbol and select Symbol Tools > Explode > to Original Layers.
7. Use the layer manager to delete the current layer (provided it has nothing on it).
8. Edit the symbol to your liking.
9. Close the symbol (File > Close or Ctrl+F4) and select YES to save changes.
10. You now have a unique symbol based in the drawing only.
- 1. Double-Click on the symbol you want to "make unique"(or use the cool new Shift+Right Click if you have Inferencing turned on and have installed the new Beta) to open up the symbol editor.
2. Go to Edit > Clipboard Select (Ctrl + E)
3. Either choose area (F3) and select everything (with Layer Search on), or hit Ctrl+A (with Layer Search on) to select everything, then hit copy (S5 or Ctrl+C)
4. Select an insertion point (if you had that option set).
5. Close the symbol (File > Close or Ctrl+F4) and select NO to save changes.
6. Go to Edit > Paste as Symbol (Shift+Ctrl+V) and insert the symbol where you want it. You will be prompted to give the symbol a name (the default is a long number string which seems to be unique, probably related to the time that you inserted the new symbol).
7. Double-Click on the new symbol (or use the cool new Shift+Right Click if you have Inferencing turned on and have installed the new Beta) to open up the symbol editor.
