Reference Manager Xref Not Selected
You know how when you double click an xref or ctrl+right click an xref to open the Reference Manager and the xref you used to launch the manager is not highlighted sometimes? I had always closed the Reference Manager and tried again and usually the 2nd time the xref would be selected in the list. Instead of doing that I found that if you just click the Apply button it will refresh the manager and the xref you launched the manager with will be highlighted as expected.
