#13486 by David Porter
Tue Aug 29, 2006 5:53 pm
You can use Erase, Mask, By Entity, then select Point. You can now window around an entire drawing or area and with Layer Search turned on or off and only snap points will be erased.
#13492 by Roger D
Wed Aug 30, 2006 11:15 am
A while ago my Engineer was saying it took a long time to modify the dwg export since he did not like to see all of the dots. I said no problem, and added the command alais:
[DP]
comment=Select and delete points using SelSet5 renamed to DePoints
alias=;^S2^F4^F5^F0^F0^F1^F5^S0^F5^F5^DePoints^$^S0^F2^F5^F0^F1^F5^S0^S0^F3^-10000^$^-10000^$^20000^$^20000^$^S0^S0^F7^F5^S0
While it took him hours to delete all the points, it took me seconds.
It assumes using relative cart. to enter an area 10,000 feet to the bottom left to 10,000 top right of the current cursor position.
