Tweaks for the DataCAD interface
Posted: Sun Mar 27, 2005 9:29 pm
Hello:
At the DBUG meeting the other night, Evan showed us lot of the things that you can do to adjust/tweak/fine tune/obsess about in the DataCAD 11 interface. One of the lesser known things that is possible to do, is to widen the pulldown areas of the Status Panel (which is the area the has all the hot buttons for the LM, Linetype Menu, etc., and shows the active layer name, the active color, active GTV, etc.). For example, here's the way I have the Status Panel set up here at home on my single 1280x1024 LCD monitor:
click on image to see a larger version
How does this work, you may ask? Just add a line like this to the [Status Area] section of your DCADWin.INI file:
[StatusArea]
DropDownWidth=xx
...where xx is the number of additional pixels to add to each pulldown. In the case I'm showing, the number is 91, and for a typical side menu location, I have found that 25 or 27 works well.
[StatusArea]
DropDownWidth=xx
