#17415 by Nick Pyner
Sat Dec 16, 2006 10:15 am
A DataCad state of mind in Renderise Live has to be as much by good luck as good management. Nonetheless I have finally worked out that you can sort out GTVs in RL. What you have to do is stay away from "views" and think in terms of planned parenthood.. A "parent" is a GTV and the children are the layers within. You have to detach the layers from the original parent, make a new parent for each GTV and then attach the loose layers to same. It's all on p298 299 of the manual.
I think a better option is to break up your model into GTVs in DataCad and export each GTV as a separate DXF. THose DXF will keep the right relationships with each other when they are loaded into RL.
#36548 by Mark Bell
Wed Jun 04, 2008 4:25 pm
Hi Nick,
...RL doesn't remember lights that have been set up for each view, only the cameras used and view angles....not quite as good as DataCAD's GTV's....but useable.
