Old Cheap Tricks Ware
PostPosted: Wed Oct 01, 2008 9:32 am
by bca-arch2
I have discs of Cheap Tricks Ware Vol one and two. I haven;t needed to access them since we upgraded to Datacad 12. I just tried to load one of the template files and it could not locate datacad folder in the setup. Is there a way I can load these templates in Datacad 12?
PostPosted: Wed Oct 01, 2008 10:04 am
by Tony Blasio
If you Explore the CD there should be a DCAD folder on it. The folders below mimic'c the folder structure of older DCAD. If you can find the SYM folder and the folder below that contains the old SM3 files you can just copy it to the current DataCAD\Symbols folder and then use the Symbol Browser to view them.
PostPosted: Wed Oct 01, 2008 10:25 am
by bca-arch2
Thanks that worked fine. I was trying to get them to work as a template
PostPosted: Wed Oct 01, 2008 11:13 am
Hi,
You're much better off using the Symbol Browser; since the templates would require you to edit the paths in the .tpl file to match where you actually locate the symbols. This is the raison d'ĂȘtre of the Symbol Browser.
If you need to re-order the symbols in the SB, you can do this by adding a numerical prefix -- 00-, 01-, 02-, etc.
PostPosted: Wed Oct 15, 2008 6:45 pm
by Daniel Kaczor
I agree that using the symbol browser is the way to go.
But, if you want to run the setup for any of the older install disks, open Notepad, then save as dcad.exe to your DataCAD folder. No need to type anything in NotePad, just point the installer to the DataCAD folder.
Old Cheap Trics ware
PostPosted: Tue Aug 03, 2010 2:22 pm
by David Ramey
The real problem is getting stuff from Dave Henderson in AU. I use a lot of his stuff but he has disappeared.
