Is there any way to get the the ini file from dcad18 to work in dcad 19? When I tried to use it I got a message that it was missing an rgb file.
You could copy the portion of the .ini file that you need. You looking to copy the pathnames?
I found out what the problem was. I had to add our companies RGB file and I had to change the path from the server to my own drive for the support files.
I can state, categorically, it's really not a good idea to copy a previous version's INI file to a new installation.
David A. Giesselman
Senior Vice President & CTO
DATACAD LLC
dave@datacad.com
DATACAD LLC
dave@datacad.com
David A. Giesselman wrote:I can state, categorically, it's really not a good idea to copy a previous version's INI file to a new installation.
I kinda get the idea you don't think it's a good idea then, in fact I'd go as far to say "it just shouldn't be done"
"Life isn't about dawdling to the grave, arriving safely in an attractive, wrinkle free body, but rather an adventure that ends skidding in sideways, champagne in one hand, strawberries in the other, totally worn out, screaming 'yeehaaa, what a ride!"
Users browsing this forum: Google [Bot] and 32 guests
