#70497 by Mark F. Madura
Thu Dec 22, 2016 11:50 am
Here are all the files and settings that are transferred during a new installation of DataCAD 19
(If you choose to transfer files and settings from the previous version that was found)
Fonts:
\DataCAD XX\Fonts
*.chr
*.shx
chr2shx.dat
Report Forms:
\DataCAD XX\Report Forms
*.frm
Toolbox Macros:
\DataCAD XX\Macros
*.dmx
*.dcx
*.dor (AEC Model Door Types)
*.win (AEC Model Window Types)
*.msg (Message files)
*.lbl (Label files)
*.str (3D Stairs Stair Types)
The following macros are not compatible with DataCAD 11 and later.
Estimator Link
ESTLINK.DCX
Layer Utility
LYRUTIL.DCX
Symbol Explode
SYMEXP.DCX
View Master
VIEWMAST.DCX
Support Files:
\DataCAD XX\Support Files
dcadwin.pat (Classic Hatch Patterns)
dcadwin.pat.ini
dcadwin.mcr (Keyboard Macros)
dcadwin.lin (Classic Line Types)
dcadwin.dca (Command-line Alias)
*.dmf (Material Files)
text.stl (Text Style (Obsolete))
wall.stl (Classic Wall Style)
*.tbl (DWG Color Mapping Tables)
*.ini (DWG Transfer Settings)
*.lit (Shader Light Settings)
dcadwintoolbars.gui (Toolbar GUI Settings)
dcadwindialogs.gui (Dialog GUI Settings)
ObjectViewer.gui (Object Viewer GUI Settings)
Dimension Styles:
DataCAD XX\Support Files\Dimension Styles
*.dimstyle
Color Palettes:
DataCAD XX\Support Files\Color Palettes
*.rgb
Program Defaults:
DataCAD XX\Support Files\Program Defaults
dcadwin.ang (Default Angles)
dcadwin.dec (Default Decimals)
dcadwin.dis (Default Distances)
dcadwin.scl (Default Scales)
Toolbars:
DataCAD XX\Support Files\Toolbars
*.* (All Files)
CST - Context-sensitive Toolbar
DTB - DataCAD Toolbar
PNG - Icon Bitmap
Hatch Patterns:
DataCAD XX\Support Files\Hatch Patterns
*.dhp
Line Types:
DataCAD XX\Support Files\Line Types
*.dlt
User Dictionary:
DataCAD XX\Support Files\Dictionaries
userdic.tlx
Pen Tables:
DataCAD XX\Support Files\Pen Tables
*.pen
*.dpf
Default Drawings:
DataCAD XX\Default Drawings (including sub-directories)
*.aec
Wall Types:
DataCAD XX\Support Files\Wall Types (including sub-directories)
*.wls
Door Types:
DataCAD XX\Support Files\Door Types (including sub-directories)
*.dor
Window types:
DataCAD XX\Support Files\Window Types (including sub-directories)
*.win
Text Styles:
DataCAD XX\Support Files\Text Styles (including sub-directories)
*.txtstyle
Plotter Settings:
DataCAD XX\Support Files\Plotter Settings (including sub-directories)
*.dps
Sun Shader:
DataCAD XX\Sun Shader\NX\Support Files
geogdata.ini
Note: These files will not be transferred if they are located outside of the DataCAD program folder.
#70499 by joshhuggins
Thu Dec 22, 2016 12:23 pm
Users browsing this forum: No registered users and 66 guests
