Number of Points Snapping
Thu Jan 05, 2017 4:38 pm
It doesn't seem that the number of points snap setting works on associative dims - is this correct?
Re: Number of Points Snapping
Thu Jan 05, 2017 4:40 pm
by David A. Giesselman
That's correct. It could be added if needed.
Fri Jan 06, 2017 9:12 am
This could be helpful sometimes.
Fri Jan 06, 2017 9:29 am
So, Number of Points along the dimension line itself?
Fri Jan 06, 2017 12:30 pm
Fri Jan 06, 2017 1:41 pm
Correct - this saves doing the math, in some situations.
Fri Jan 06, 2017 1:49 pm
Done for the next Subscription update.
Fri Jan 06, 2017 2:22 pm
by Paul Nida
Until it is done you could just use divisions to put snap points along the dimension line to snap to and it should work the same.
Fri Jan 06, 2017 2:41 pm
