How do I set a permanent object snap preference? Mine keeps changing the settings while working on a drawing.
That's odd - you are using the Object Snap menu or the new toolbar icons, to toggle what you want? Are all the settings toggling off, or just some? If the latter, which ones?
If you work with Caps Lock on and press the 'X' key that will take you to the OSnap settings to show what's selected. There could be other keyboard shortcuts you're accidentally pressing that toggles certain settings on/off - you might check in the manual for these.
DataCAD user since v4!
Regards
Mark Bell
Principal
ATELIER MARK BELL
Australia
Regards
Mark Bell
Principal
ATELIER MARK BELL
Australia
Thanks guys. I do work with caps lock on and I do press "x" often and I'm sure I am accidently pressing other keys. Its not really that big of a deal. Just wondered why that was happening.
