I have just loaded DataCAD 19 and want to use the 2D wall styles I have created in 14. When I go to the Wall Style Manager in 19, my 14 wall styles do not appear as available. I've created a lot of wall types and don't want to have to start all over again. I have tried searching for them but have not found a folder where they are located. Can anyone tell me where they are in 14 and how to move them to 19?
Have you looked in the \Support Files folder - there should be a DataCAD Style File(s) which can be edited in Notepad etc>? You would copy those in v14 across to v19.
DataCAD user since v4!
Regards
Mark Bell
Principal
ATELIER MARK BELL
Australia
Regards
Mark Bell
Principal
ATELIER MARK BELL
Australia
Should be a Wall.STL file in the Support Files folder that you can just copy to your Datacad 19 Support Files Folder.
Thanks! - Josh
Josh's Digital Downloads is come back online soon. Stay tuned.
Thanks for the help - Wall.STL It was easy to find once I knew what to look for.
Thanks again - This will same me time.
