Revised symbols not correct
PostPosted: Wed May 17, 2017 9:11 am
by dennisnorton
I am sure this has been discussed in the past, but can't find the solution...
I still have problems occasionally when I modify symbols. The updated symbols still show up incorrectly in the drawing where the symbol was corrected. I have tried regenerating, reloading, purging symbols, etc... but nothing seems to work. I open a new file and the symbol is correct, but the original file is still wrong. I have also tried editing the symbol for the particular drawing, but it just doesn't regenerate properly... What am I not doing correctly?
Re: Revised symbols not correct
PostPosted: Wed May 17, 2017 1:33 pm
Could the path have changed or there are two versions of the same symbol in the drawing?
PostPosted: Thu May 18, 2017 8:08 am
I would try reloading (or replacing?) the symbol.
Did you rename the symbol after editing it?
