#71781 by Roger D
Wed Jul 05, 2017 9:09 am
When I close a file, it is at 1/4" plot scale. When I open the file later, it opens at 10' scale (3 scale items down the list). Files should open up at the same scale when closed.
Tested on file, closed and reopened seconds later, still happens.
#71782 by David A. Giesselman
Wed Jul 05, 2017 9:21 am
Are you Saving the file or merely closing it?
#71783 by Roger D
Wed Jul 05, 2017 9:25 am
Closing the file, but not DataCad.
#71790 by David A. Giesselman
Wed Jul 05, 2017 1:40 pm
Roger D wrote:Closing the file, but not DataCad.
When you close the file, are you answering Yes when prompted to save changes?
#71796 by Roger D
Wed Jul 05, 2017 4:23 pm
yes.
#71800 by David A. Giesselman
Wed Jul 05, 2017 5:16 pm
Is this happening in one file only or all files? If only one file, send the problem child to me.
#71802 by Roger D
Thu Jul 06, 2017 7:37 am
Just check 2nd file, another project. Saved while showing 1/4 scale. ReOpened at 1/4" scale. (2 up the scale list).
But, different files, different scale list. They are both opening up at scale located at F10??
Another item that has started with a recent beta. When opening, the file doesn't always display everthing, have to "u" key to see all that should be there.
#71805 by David A. Giesselman
Thu Jul 06, 2017 8:53 am
Please check the [Printer] section of your INI file for the following key:
Settings Auto Load=FALSE
Is it present?
#71806 by Roger D
Thu Jul 06, 2017 9:34 am
Present as below
Settings Auto Load=RogerPrint.dps :oops:
Can I remove/change the line from the .dps file so it doesn't force the change?
Last Plot Scale=10
#71807 by David A. Giesselman
Thu Jul 06, 2017 10:18 am
No sir. If that line is not present, it will default to whatever scale is at position 1. Do you not use Default drawings?
#71808 by Roger D
Thu Jul 06, 2017 12:57 pm
Do use defaults, but still find sometimes it doesn't load the correct plotter settings from the default.
Will have to try to track that better.
Users browsing this forum: Yahoo [Bot] and 2 guests
