Dimension Text not displaying
Mon Jul 17, 2017 8:07 am
by dennisnorton
For some odd reason, dimension text does not display, except the inch sign (in neither DC18 or DC19). The font displays in text mode, but not in dimensions. Also, I tried to plot the file to see if it was a display issue, but the machine hung up like there was a problem finding the text. I then entered new text in both shx and ttf but all that displays is the inch sign. Of course I have a deadline today (why would an issue like this occur when there is plenty of time of figure it out?). Any suggestions? Very strange.
Re: Dimension Text not displaying
Mon Jul 17, 2017 12:13 pm
by Joseph Baron
Try resetting the 'Scale Type'.
Tue Jul 18, 2017 5:07 am
by dennisnorton
Thank for the suggestion, but that didn't work either. I have tried everything - fonts, scales, scale type, exploding, upgrade to latest DC, PAKing, layer save and reload..... Whenever the dimension layer is on, the file just works continuously without saving and I have to shut down DC. I even created a new file and I still can't get dimension text to display or plot or save. Must be something corrupted in the dimensioning programming. Any suggestions?
Tue Jul 18, 2017 7:24 am
I seem to remember this being caused by an obscure dimension setting, like Limits - if it is toggled on, try toggling it off. Or, look at Dimensions / Linear / Dim Style / S8 Dimension?
Tue Jul 18, 2017 7:34 am
by dennisnorton
Thanks, Neil. That worked. When I turned off Rounding, all of the text displayed!!! I don't know why Rounding was on - I never do that intentionally. Limits was not checked, so I then noticed rounding was on and voila!!! Fixed.
Mon Apr 02, 2018 11:01 am
by ChrisHartman
Neil Blanchard wrote:I seem to remember this being caused by an obscure dimension setting, like Limits - if it is toggled on, try toggling it off. Or, look at Dimensions / Linear / Dim Style / S8 Dimension?
I have this condition..but Limits isn't on. really confusing. There's definitely a setting off here because when I paste this all into a fresh drawing it works fine. I can just set this particular drawing on fire, but I'd like to hunt this down so if it happens again I can pinpoint the issue.
Any other suggestions? I've attached the file here.
Mon Apr 02, 2018 11:12 am
by David A. Giesselman
ChrisHartman wrote:Neil Blanchard wrote:I seem to remember this being caused by an obscure dimension setting, like Limits - if it is toggled on, try toggling it off. Or, look at Dimensions / Linear / Dim Style / S8 Dimension?
In the Linear dimension menu, go into Dim Style and select Rounding. Within that menu, toggle Off Round It.
Round It.JPG (8.35 KiB) Viewed 7235 times
