printer setup
Mon Feb 19, 2018 10:44 am
by Bob Urbanek
When I setup the number of copies to print,it only works once. It used to remember the amount of copies until I either manually changed them, or I restarted DCAD.
I looked in the DCAD ini, but couldn't find anything.
Re: printer setup
Mon Feb 19, 2018 5:32 pm
by David A. Giesselman
Bob Urbanek wrote:When I setup the number of copies to print,it only works once. It used to remember the amount of copies until I either manually changed them, or I restarted DCAD.
I looked back through my code history and couldn't find any point at which we saved this value between drawing sessions.
Re: printer setup
Tue Feb 20, 2018 5:38 pm
by Bob Urbanek
I just had something I needed to print. I set up to make 3 copies. When I saw the preview, I noticed I had missed something.Closed the previewer, made the change, gave the print command again, checked the setup and found that it had reverted to one copy.
It never used to do this. I have experienced a number of odd things happening, since I upgraded to V19.
Bob
Re: printer setup
Sun Feb 25, 2018 11:08 pm
by Bob Urbanek
I had taken advantage of the deal to upgrade to V19 before the first of the year. I just recently noticed that there was an update available. I did the update, and it seems to have rectified the problem.
Bob
