SYMBOL ATTRIBUTES ROTATING IN XREF
Posted: Tue Mar 06, 2018 11:52 am
When create an attribute that is drawn as horizontal but rotate with the angle locked and fixed text and rotate it when you bring it in the plan the text shows up fine on the base drawing but when you use the base drawing as an xref the attribute reverts to being vertical. Is there a way to correct this short of having an attribute for each situation of x and y?
