vincent.team13 wrote:Hello
is there a translation patch in French for DATACAD 19 ?
if no, can we change the menu tabs to translate them into French?
Thank you for your reply
Vincent
Hello Vincent,
Here are the French message and label files for DataCAD 19. >>
French Message and Label files for DataCAD 19
(144.42 KiB) Downloaded 609 times
You can replace the files in DataCAD 19\Support Files\Messages and Labels\ with these.
We now have French and Spanish editions of DataCAD 20 which you can download from the following links:
DataCAD 20 French Edition:https://www.datacad.com/xxdemo/fr/DataCAD20Setup.exeDataCAD 20 Spanish Edition:https://www.datacad.com/xxdemo/es/DataCAD20Setup.exeNote: You can enable DataCAD's built-in label file editor by setting the key, LabelFileEditor, to TRUE in the DEBUG section of DCADWIN.ini.
When the Label File Editor is enabled, you can [Shift] + Click on any left-hand menu button to display the corresponding Labels and Hints. Once you've made a change, select
Update to update DCADWIN.lbl / DCADWIN3.lbl in memory. Then select
Save to LBL File to update the files on the hard drive.
