1. Assuming you're using smart entities, check you paths/folders haven't changed.
2. If you mean they were visible in the drawing area, now they'r e not, try pressing 'U' to update the display list. If the doors were on a separate layer to the walls, check the layer is on and there are entities on that layer - they could have accidentally been erased?
...there could be a number of reasons they're not showing - you'll need to provide more info about the situation.
DataCAD user since v4!
Regards
Mark Bell
Principal
ATELIER MARK BELL
Australia
Regards
Mark Bell
Principal
ATELIER MARK BELL
Australia
When I'm in the 3d door manager, only the default door appears
In the Door Type Manager, make certain that Display External Types is checked.
David A. Giesselman
Senior Vice President & CTO
DATACAD LLC
dave@datacad.com
DATACAD LLC
dave@datacad.com
