Something happened -again. I have been using the same method to dimension since DCAD5. Didn't change anything. When I dimension something, the witness line would stay anchored where I snapped to and I would drag the dimension line down to where I wanted it.Now the witness line is offset considerably from where I snapped to. I have tried to change settings, and I can't fix it. What am I missing? I can go to older drawings, and it still works correctly. Any suggestions?
Maybe Fixed Incr. got turned on under Dim. Style
Maybe also check under Object Snaps that Offset is turned off.
Thanks! - Josh
Thanks Roger and Josh,
After I posted yesterday, I just got frustrated and shut down for a few hours. When I started up again, the problem was gone. ?????
Thanks for your help.
Bob
Bob
