fix text on mirrored symbol
PostPosted: Tue Dec 04, 2018 1:20 pm
by GARY247
Is there any way to get the dimension line to show correctly when you mirror a symbol?
Re: fix text on mirrored symbol
PostPosted: Tue Dec 04, 2018 3:50 pm
Sure - Control/Right Click on the symbol, and select Fix Text on the menu.
PostPosted: Wed Dec 05, 2018 11:30 am
by GARY247
I had tried that and it did not work. Is there a certain way to do the dimension to begin with so when you mirror the symbol is appears correctly?
PostPosted: Thu Dec 06, 2018 8:42 am
I missed that you have a dimension in the symbol - is it a associative dim, or exploded?
PostPosted: Thu Dec 06, 2018 10:58 am
by GARY247
I tried the dimension both associated and exploded in the symbol. It made no difference.
PostPosted: Thu Dec 06, 2018 1:32 pm
Can you post a screenshot of before and after of what you are seeing? Also have you tried it in a new empty file?
PostPosted: Thu Dec 06, 2018 1:44 pm
by GARY247
Here you go. When you mirror it the text whether it is associated or exploded the text on the mirrored copy appears below the line instead of above it.
