#75759 by Lars
Mon Feb 25, 2019 11:09 am
How do I change my drawing unit input from the default (feet.inch.fraction input?) I want something thats quicker... like true decimal inches with feet input as an option. For example... instead of having to do this... (0.0.1/2) ... It would be so much faster to just type this... (.5) ... or (.25) RATHER than getting the output 5/32, or 25/32.
Basically I want decimal inches to always to be my input. UNLESS I use FEET which would look something like this... 25'3.125
How can I do this?
Thanks!
#75761 by Roger D
Mon Feb 25, 2019 11:39 am
You will find that in Settings, Scale Type, select Inch Decimal if that is what you want.
With the current setting of Arch, you could also enter as ..16, the base unit is 1/32" of an inch, so ..16 = 16/32 or 1/2".
#75762 by joshhuggins
Mon Feb 25, 2019 11:42 am
In the Utility menu, F0 Settings, F2 Scale Type you can try to set either Decimal or Inch/Decimal and see what works best for you.
#75771 by ORWoody
Mon Feb 25, 2019 1:58 pm
Lars:
If you like just using the period as your input control, rather than ',",/, etc. DataCAD lets you do that. I always use the period. For example, 5'2 1/2" would just be entered as 5.2.1.2. Granted, that is slightly longer than a straight feet, decimal entry, but I can't remember into the 32nds of an inch decimals equivalents, but I can type 5.2.7.32 easily. The period is an instant separator for distance elements.
That is my favorite thing about DataCAD.... Well, that and about seventy thousand other favorite things about DataCAD.
Seriously. Try the period input and all will be good.
Of course, if you have a reason for decimal feet or decimal inches, that capability is there too
Woody
#75804 by Lars
Wed Feb 27, 2019 8:40 am
:lol: Its like learning decimals in Elementary School again. Only this time around they're teaching us that "..16 = .5" :? (which if you have kids, you know that's not far from the truth.) Its hard enough with a direct fraction/decimal relationship. Now its a fraction cypher on top of it? I'd rather not relearn my fractions in how many 1/32 = 1/2.
Thanks, but I'll stick with .5 = .5
:lol:
Nice to know I dont have to keep using the 0's though.
Thanks!
#77312 by Ted B
Sat Nov 23, 2019 12:19 am
Hehheh, ...I have the same annoying problem with Sketchup Layout. While the Sketchup modelspace handles units of length in various formats, Layout is paperspace and you have to dbl-check your units and paperspace scale when drawing or dimensioning. When drawing directly into Layout, I have to use the apparent scale. For an object like a roof plan in 1/8th-scale; to accurately enter a distance in Layout one foot is "1/8", and 16-inches is "16/96". I keep a little cheat sheet under my desk-glass ..next to the one for common lettering-hts. in DCAD at various output scales!
I have DCAD drawings where I have different scale-types in the same file, typically for site-work. I'll have a large siteplan in 1"=200-ft Engineering, then an xref'd detail dimensioned at 1/16th or 1/8th Archtectural. I just leave myself a note off-frame below the tiled and nested titleblocks to remind myself to change the scale-types setting before plotting so the dimensions are the correct type. I just can't use mixed scale-types on the same printed sheet when its time to plot...
While the surveyors and civil types are used to decimal feet, most trades on-site want feet-inches. I used to deal with a steel guy who worked in feet-decimal inches... May the old gods and the new protect us from metric.
Users browsing this forum: No registered users and 121 guests
