2d3d casework trouble
PostPosted: Wed Mar 18, 2020 7:00 pm
by rdberry
when I use the 2d3d casework template or the 3d stairs,
and try to go to elevations or the hide command, all I get is a single line.
This is only on one drawing that I'm working on. However,
I tried to copy those cabinets to another drawing that
worked with the 3d stairs. When i hit elevations, they still
came up a straight line.
I'm sure there is a setting that i hit and can not find.
Any suggestions.
Robert " Butch Berry
architect
Eureka Springs, AR .
Re: 2d3d casework trouble
PostPosted: Thu Mar 19, 2020 5:50 am
by Mark Bell
1. Maybe check the Projection Pad has Ortho (Plan view) selected as it could be set to a 3D view such as Parallel/Iso etc.?
2. Also turn off any clipcubes that may be on.
3. Identify the line and if it is "hundreds of kilometres" long, delete it, then regen the drawing.
