Hanging onto old Datacad products
Sat Oct 17, 2020 8:25 am
by esme103
Is there a reason to keep a Datacad 8 disk and the square key that you had to connect to your computer?
Re: Hanging onto old Datacad products
Sat Oct 17, 2020 5:42 pm
by Mark Bell
To give you the opportunity to create some find memories later on ...
DataCAD 8, from memory, came bundled with Visual Reality so you may need to reinstall it at some time if you still use it?
Sun Oct 18, 2020 12:35 am
Recent versions of Datacad seem to open all of the DC5 and SM3 symbols just fine for me, so unless you have another reason other than nostalgia, I would say no.
Sun Oct 18, 2020 6:09 pm
by esme103
Thank you Mark and Josh. I don't even know whether it is possible to find a cord that plugs into the key and the printer and the computer so this is probably a moot question. I have the same key for DataCad 9. Will the disks for these function i if put into a computer and why would one need them if you have DataCad 19? I am sure I have some projects saved on Zip disks and I don't have a device to read them anymore. I guess that the answer is that all these things are good for the garbage can. I value your replies though.
Sun Oct 18, 2020 7:59 pm
by Mark Bell
May be donate it to a local op shop, school or drop-in centre....it might make its way to become some kids stocking filler for Christmas?
Mon Oct 19, 2020 11:48 am
I think to run DataCAD 8, you would have the first install Win98 into something like VMware? You could try installing it in a recent flavor of Windows, but there is a good chance it wouldn't work.
Thu Mar 04, 2021 8:23 am
by Nick Pyner
Mark Bell wrote:To give you the opportunity to create some find memories later on ...
I think it is right that Visual reality came with Dcad8, but it could be installed independently. VR probably won't work on later versions of windows anyway. I know Simply 3d doesn't, and at least that was a native windows successor. Both packages work on XP.
