Page 1 of 2
Print in Color
Sat Jun 30, 2018 6:34 pm
by rgleason
I believe we used to be able to print in color without jumping through hoops.
What is the purpose of Printing > WYSYWG?
We seem to have added functionality in Pen Tables for color... and have lost some simple functionally.
Why can't I just print in color with the pen table colors?
Nothing seems to work.
Even when I try I simple color mapping using the pen tables
IE pen 1 to cyan there is no mapping.
Is this a print driver problem? No, I've tried several printers.
Re: Print in Color
Sun Jul 01, 2018 11:48 am
Are you referring to Pen #1-15. Make sure "Al Black" is not checked.
Also, Pen#16 is the screen color.
WYSIWYG |Printed output will look like what is displayed
Re: Print in Color
Thu Jul 05, 2018 8:45 am
by rgleason
Code: Select allAre you referring to Pen #1-15. Make sure "Al Black" is not checked.
Donald
I've change all standard colors to be pen#16 Have WYSIWYG button selected,
Still B&W when I go to print.
I've forgotten how to do this, if I ever did it. Perhaps not, we used penwidth forever.
I wonder what I am missing here.
Re: Print in Color
Thu Jul 05, 2018 8:52 am
It's really Roger, but I've been called worse.
Can you do a screen shot of you Pen Table?
Re: Print in Color
Thu Jul 05, 2018 8:59 am
by rgleason
Roger, I am sorry. Don't know what I was thinkiing.
Had turned off "All Black"
Here is the screenshot
Re: Print in Color
Thu Jul 05, 2018 9:22 am
Looks like that got solved. Good work for the day. Can we take the rest of the day off?
Re: Print in Color
Thu Jul 05, 2018 10:14 am
by rgleason
No not actually, when I go to print it comes up in B&W
The color you see is just the screen display.
Happy 4th! Can't sail so I am doing a drawing for the new winter cover.
Re: Print in Color
Thu Jul 05, 2018 10:35 am
by rgleason
So in another drawing, same pen table. Now it looks like it will plot in color because the color is showing in the preview window.
What is different? ...Beats me! Still don't know the answer. One drawing works the other doesn't. BizarreO. Only difference I know about, is I selected "In Order"
Re: Print in Color
Thu Jul 05, 2018 11:04 am
by David A. Giesselman
In the
Tools drop-down menu, what does your Palette file look like?
Re: Print in Color
Thu Jul 05, 2018 11:53 am
by rgleason
Thanks, the two color pallettes for the two different drawings look the same to me.
Here is the palette for the drawing that isn't showing color in the print preview screen.
Re: Print in Color
Thu Jul 05, 2018 12:01 pm
by rgleason
Here is the color palette for the drawing that works.
Re: Print in Color
Thu Jul 05, 2018 12:03 pm
Re: Print in Color
Thu Jul 05, 2018 12:05 pm
What if you saved the palette from the file that works, then load that palatte into the one that doesn't??
Re: Print in Color
Thu Jul 05, 2018 12:55 pm
by rgleason
Don't know if it would help any, but maybe before you open it, do a File/Repair on the file. Might clean up something?
I tried saving the file to a new name, but perhaps that does not do it.
It occurred to me that this file had an image attachment to get the basic shape of the hull right by tracing.
Since that was long ago, the image has been moved and there is a message that comes up about a missing image file each time I open it.
Might that be the problem?
Tried a repair. The colors are still not there.
Looking to remove the orphan bitmap. Can't find it.
Re: Print in Color
Thu Jul 05, 2018 1:01 pm
by rgleason
Tried save as the palette for the other drawing, then selected that defaut-rick plalette and it really did not change anything. Good idea though.
Maybe it is that orphan image?
