forum.datacad.com • View topic - 3D Elevations
3D Elevations
PostPosted: Fri Feb 08, 2019 7:06 am
by smash
Why are my 3d elevation views not showing on one drawing? What did I turn off?
Re: 3D Elevations
PostPosted: Fri Feb 08, 2019 11:54 am
Something clipped cubed?
Re: 3D Elevations
PostPosted: Fri Feb 08, 2019 12:26 pm
by smash
Shouldn't be. There is dot on the screen and I can scroll in and it stays the same. I have been working on this plan for 40 hours. I added some walls this morning and that is when it started.
Re: 3D Elevations
PostPosted: Tue Feb 12, 2019 3:50 am
by caddboss
You could try to find out if your model "escaped" very far from the world's origin. That dot may actually be your model ;) If so, try to bring it back near to origin. Just a guess though...
Re: 3D Elevations
PostPosted: Wed Feb 13, 2019 2:52 pm
by ORWoody
If you identify the dot several times and see different answers, it's likely the model. If it simply identifies as point, then the model is far out of sight. That would mean that you will have to relocate it closer to "zero, zero".
Try turning off most of the layers and checking to see if the window function results in the same dot. If you see the layers correctly, begin turning on other layers without windowing in or out.
Good luck,
Woody
Re: 3D Elevations
PostPosted: Wed Feb 13, 2019 3:14 pm
by smash
That was it!
Re: 3D Elevations
PostPosted: Wed Feb 13, 2019 4:31 pm
What I like to do in these situations is
- First and foremost, force save! :D in case the following steps crashes my drawing which can happen with these lost entities. You could try a Save As at this point but sometimes those crash when trying to save and you could loose work done since the last save. I prefer the force save myself.
- Zoom into where my main drawing entities are
- Cut my good stuff to the clipboard
- Preform an Erase, Select All (Ctrl+A) (note your attention bar at this step to see what gets deleted)
- Then Paste my main entities back into my drawings using Absolute Zero, making sure my enlargement factors are set to 1, original layers is on.
- If everything looks good, Force Save again.
- Try my zoom extents or GTV with extents and see if things are working as expected.
- If good, close and save file and maybe run a File, Repair for a final bit of scrubbing.
Re: 3D Elevations
PostPosted: Thu Feb 14, 2019 6:38 am
by caddboss
Nice approach Josh! My is a bit different. I turn on ALL layers, perform Zoom -> Extents command. "Dot" (drawing heavily zoomed out) appears. Turn coords system to absolute Cartesian. After that, go to Move -> Drag -> Area and select the "dot" with Crossing option enabled. Then, for first point (drag from) just click on the "dot" and for second enter 0,0 (using space bar). Then, just try the Zoom -> Extends command again. ;) Your drawing should be displayed OK now ;)
Re: 3D Elevations
PostPosted: Mon Mar 04, 2019 10:42 pm
by gregg kett
Hi there i had a similar problem a while back, got confused with different ways to work around, but then my solution was to click repair in the drop down box before opening the drawing then open the drawing, and hey presto everything was fine.
it may not work for all problems but as a first simple step it worked a treat.
cheers
