[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 488: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 488: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 488: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 488: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 488: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 488: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 488: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 488: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 488: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 488: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 488: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 488: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 488: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 488: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 488: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 488: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 488: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 488: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 488: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 488: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 488: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 488: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 488: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 488: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 488: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 488: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 112: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 5077: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3937) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 5079: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3937) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 5080: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3937) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 5081: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3937) forum.datacad.com View topic - Drawing Error - Drawing Crashing
I have been running into a problem but it is only on one machine. The rest of my computers have Windows 7, but the one I am having problems with has Windows 10, so not sure if that is part of the issue or not.
While working in a drawing or even if it is just open, after a while the drawing gets and error, and closes. The program itself does not close, just the drawing. It also does not matter which drawing, it can be any drawing. But, if I click manually save the drawing every couple of minutes, it does not crash and I can keep working in the drawing no problem.
"Error: DataCAD (internal diagnostics) fault 36 Error from : 808"
I have tried reinstalling the program, it did not help.
Roll back DataCAD or Windows? I started having issues with 17, and that is why I updated all of my computers previously, because there was a security update on Windows 7 that didn't play well with DataCAD. Starting to get frustrated with DataCAD and windows............
I do have the latest versions of Datacad, no updates are available. As far as rolling back Windows goes, one of the computers is brand new, with a fresh install of DataCAD 21. So I have not actually updated it, so that seems like it will be an issue. The other is the latest version of DataCAD 20, and it has had this problem since day 1 when it was installed on the computer. I dealt with it for awhile seeing if there would be a fix. It was only affecting me at that time, I could deal with it. But now it is affecting others and wasting time. It also sounds like it will be a problem every time windows updates. Back when I had DataCAD 17, every windows security update caused us major issues. We had to always roll back security updates, which is not ideal, just to get DataCAD to run.
To me, this is a major issue. DataCAD needs to come up with a fix. My only other solution is moving away from DataCAD. My company has been using it for a long time, so that is not what I want to do. But if the program is not going to be reliable, it is what I am going to have to do.
I guess I will have to retract the latest update part on DataCAD 21, as I did not notice a new update was released yesterday! I am going to install and see if it fixes my issue. Fingers crossed.
