I just noticed that V.21 will only save to V.11 thru 14. I was curious about the later versions?
You don't need to do a specific save as to the more recent Datacad versions, just those older versions. You should be able to just open your v21 AEC file in Datacad v15-22. Obviously some of the functionality will be missing when opening a file in the older versions.
