Anyone have any clever ways to find a symbol that has a specific linetype in it? I have drawings that have a bad linetype in them but the linetype must be in a symbol because I've tried doing a change linetype using mask for the offending linetype and there are no more drawing level entities left that have the linetype so there must be entities within some symbols that have it assigned but I can't seem to find them. . . .
Hmm just had an idea. I am going to create a new linetype with the same name as the bad linetype but make the pattern for it so stinkin' huge it will surly stand out. Then I can hopefully reload the new linetype from the hard drive and I should then be able to find the symbols that have the entities within. Will let you know how it goes....
