I draw dimensions so that the dimension text is drawn in line. The dimension text is drawn with a knockout that obscures part of the dimension line. This is what I want.
However when I reposition the dimension text to some other place on the dimension line I find that the dimension text no longer hides the dimension lines. This has happened over a number of versions of Datacad.
How do I get the knockout to work?
