#76784 by Lars
Wed Jul 24, 2019 12:58 pm
I'm having an issue with Line To Poly. When I convert a set of lines, the result skips control points and even creates its own. Can I change the sensitivity of Line To Poly so it accepts each line/curve endpoint as part of the polyline? Starting Line To Poly from different line segments produces a different result, however, it always leaves out 3 control points. Is there a limit that I can raise?
After
Before
#76788 by Mark Bell
Wed Jul 24, 2019 5:59 pm
Have you tried using the contour search instead, which would also be quicker allowing you to just 'touch' the inside of the line work to generate the polyline?
#76799 by artmanvt2000
Fri Jul 26, 2019 10:12 am
Another option would to be select the option "KeepLins" (Keep Lines). After the polyline is created, you can and points as needed to pick up the missing points and lines.
