#77598 by Roger D
Sun Feb 16, 2020 3:27 pm
3d menu, explode?
Then you might need to use the 3dline convert.
#77603 by dhs
Sun Feb 16, 2020 6:13 pm
If you have drawn your objects using vertical polygons then the explode will produce 4 3d lines for every polygon (1 at the bottom of each polygon, one at the top, and one for each of the vertical sides). The 3dline convert macro will leave any vertical 3d lines unchanged, so you will need to erase them manually (hopefully not that difficult using an entity type mask). You will also probably want to delete one of the 2D lines (either top or bottom), most easily done using the 3D erase command in an elevation view
#77604 by Roger D
Sun Feb 16, 2020 6:23 pm
Other way to delete the double top/botttom line if you have alot might be using the 3dMenu, Hide, with under Options, turn on Del Double and then run the hide command.
