Chris wrote:I was noticing that the Toolbar Lock is also outside of the configure menu.
I think it's in the View menu so it's near the main View\Toolbars dialog launcher.
Not sure if this is a default setting or not, or if it's something you might want to set, but if you open
C:\Datacad XX\Support Files\Messages and Labels\DCADWIN.mnu in Notepad, and search for
Lock Toolbars you can add a quick key to it in between the ||.
I have mine set to
Lock Toolbars|Ctrl+L|
You can look at some of the other examples within the dcadwin.mnu file for ideas on available shortcut options or other commands you may want to add a quick key combo for.
