#78578 by joshhuggins
Sat Aug 15, 2020 4:13 pm
Is there a way to have a Symbol Attribute that is going to use Lookup to have a Default Value at Symbol insert? We used to be able to set the Value when using Lookup. Now when we set lookup, the value field becomes greyed out and it removes whatever is in the Value field. Symbol Attributes that were created before this change still work and load the what was set in the Value field as the time of their creation fine still.
It's just nice to have the most common or safest value, loaded by default first and then the lookup is available for a custom values from the databases if needed.
