I have a small commercial drawing comprised of a few different layers, most notably and Exterior Wall layer, and an Interior Wall layer. I am new to 3D and the Rendering function, but I seem to be navigating through it ok. My issue is when I add doors they cut out the wall section above the door, and also I can add doors and windows to the 8" exterior wall, but I am not able to put an aligning cutout on the interior wall behind it to complete the opening. Any ideas of where I am going wrong? Thank you.
Any chance of posting a screen shot to better explain the situation?
DataCAD user since v4!
Regards
Mark Bell
Principal
ATELIER MARK BELL
Australia
Regards
Mark Bell
Principal
ATELIER MARK BELL
Australia
It sounds like you are drawing in "2.5 D". You are probably creating walls by giving them a "Z" height but when you insert doors and windows it does not fill in the walls above or below. I think you'll need to use Smart entities instead.
Highest Regards,
Alan T. Hendry, RA
Alan T. Hendry, RA
Thank you. I didn't have the 3D button selected. Also found a workaround by drawing in wall sections above openings which may be what needs to be done for openings anyway. Thank you again.
Users browsing this forum: No registered users and 79 guests
