#79761 by tonymaiocco
Tue May 18, 2021 5:14 pm
Hello. I’m in the process of learning to use DataCAD LT 21 and have a question about changing line types. The line type manager shows the scale of the “Dashed” embedded line type as 1, but I would like to reduce it. The “1” is in gray type, and the line type manager does not let me change it. I know that default drawings are only for the professional version. It occurred to me that the scale may not be changeable for the “LT” version. Is that true?
If so, it seems that the only way that I can create dashed lines is to draw a solid line and then make tiny erasures along the length of it. Is that the only way to make small scale dashed lines for DataCAD LT 21?
Regards, Tony
#79765 by Dave
Tue May 18, 2021 9:08 pm
Change spacing to 50 or 100
Works for me using metric. Default is around 300
DaveR
