#79794 by Totarakid
Tue Jun 01, 2021 1:14 pm
I am having real problems with certain DWG files that other consultants send me. When I import the DWG, once it starts the process it just crashes DataCAD completely.
Does anyone have a solution to this or encountered the same problem?
Kind regards
James
#79795 by MtnArch
Tue Jun 01, 2021 1:32 pm
Are you opening it directly or are you importing it into your AEC file? As I recall, long ago Clay recommended that you open a DWG file directly in its own AEC file, and then either cut-n-paste the entities into the drawing you want it in, or save it out as an AEC file and xref it in.
#79797 by MtnArch
Tue Jun 01, 2021 3:57 pm
Are the DWG files from consultants that may be using add-on packages that utilize Proxies? Are the problem files only from one consultant/company?
Just spit-balling right now.
Users browsing this forum: No registered users and 66 guests
