Setting "z" base and height
PostPosted: Wed Feb 23, 2022 2:04 am
by Gary24752
How do you go about setting the default distance for both "z" base and height. I know how to change it but there must be a way of setting it to begin with. I am assuming once that can be set can this be used to figure volumn and if so how or what do you have to do to get that?
Re: Setting "z" base and height
PostPosted: Wed Feb 23, 2022 9:02 am
z
hit the z key, set the z-base, z-height and those settings will continue to be used.
Caution, if you do a Identify, set all, then the z values will be changed to what that entity z's are
PostPosted: Wed Feb 23, 2022 11:50 am
Also, if you create and use base files that have your typical drawing info like borders, typical notes, typical details, etc., you can set your z-base/height in those file to a default value as well so your new projects always start how you prefer.
PostPosted: Wed Feb 23, 2022 2:35 pm
by dhs
Also, be aware of the Settings/Z ByLayr setting. If disabled then the Z base/height of all layers will be modified if you use the z shortcut ... if enabled then only the current layer will be updated.
