Can I toggle between TWO Angles when drawing?
PostPosted: Tue Apr 12, 2022 12:53 pm
by CDAVIS
I'm working on an L-shaped plan, but the two legs of the plan are not at 90-degrees from each other.
So, the one leg is not square (it's actually at 92.969-degrees).
Is it possible to toggle between the standard angle and an alternate angle, so I can draw with straight lines and not offset every line?
Re: Can I toggle between TWO Angles when drawing?
PostPosted: Tue Apr 12, 2022 1:34 pm
by Joseph Baron
Try using Geometry > Tangents to align the snap gird to the existing line.
PostPosted: Tue Apr 12, 2022 1:37 pm
by Joseph Baron
Here's a keyboard macro that allows you to select the line to set tangent to, then run again to reset to 0. Ortho should be ON.
^:^f6^f4^f3^$^
PostPosted: Thu Apr 14, 2022 10:55 am
by Joseph Baron
CDAVIS, did this work for you?
