I'm working on an L-shaped plan, but the two legs of the plan are not at 90-degrees from each other.
So, the one leg is not square (it's actually at 92.969-degrees).
Is it possible to toggle between the standard angle and an alternate angle, so I can draw with straight lines and not offset every line?
Joined
Fri Mar 11, 2022 8:49 am
Try using Geometry > Tangents to align the snap gird to the existing line.
DataCAD 22.02.14.02 BETA on my own build Gigabyte MOBO rack mounted Windows 10 Pro 22H2 x64 i7 920
Joined
Mon Feb 14, 2005 8:03 am
Location
Nashville, Tennessee
Here's a keyboard macro that allows you to select the line to set tangent to, then run again to reset to 0. Ortho should be ON.
^:^f6^f4^f3^$^
Joined
Location
CDAVIS, did this work for you?
Joined
Location
Users browsing this forum: Majestic-12 [Bot] and 20 guests
